LabWindows/CVI
Is there a way to get the App name?
Is there a function all that will return the name of the CVI application that executes that function call?  I need to determine if I'm using the real version of the app, or the simulator version.
(3,405 Views)
The name of the executable is the first parameter of main (): argv[0]. You can retrieve it at program start and store in a global variable for future use during program life.
The name retrieved is the executable one in case of a final application (YourApp.exe) and the debug executable in case you are running in the IDE (usually YourApp_dbg.exe)
(3,395 Views)
Perfect!  I never stopped to see what argv was.  This works like a charm.
Thanks...
(3,394 Views)
Following items in argv array, if any, contains the command-line parameters set when the program is launched, argc holds the counter of array elements. These are a common way to customize the expected behaviour of your application before launching it.
When operating in the IDE, command-line parameters can be set with Run options >> Command line menu tem.
(3,384 Views)
