LabWindows/CVI
how can I get started if I am not an advanced user but still want to config ATS660 external trigger?
There r 2 groups VIs provided by the company: easy VIs and advanced VIs. And set external trigger VI is in the latter one. The manual indicates that only the person who r very familar with the ATSApi Application Programming Interface should attempt using the Advaced VIs. Unfortunately I am not that kind of advanced user. If I want to learn all these stuff(like how to call the VIs in correct order), how can I get started?
I will be really appreciated if I can get some help here.  all I have now is the ATS660 User Manual and ATS-VI Software Manual. I wonder if there should be other useful manuals, like NI-DAQ user manual that can help to understand how to call/config the device in right order.
Thank u in advance.
Dyna----an eager learner
(3,042 Views)
Hi Dyna, this forum is dedicated to LabWindows/CVI: since your problem is related to LabVIEW, I suggest you to repost your question n the LabVIEW forum.
(3,035 Views)
hi ,
Thank u for ur remindation.
Dyna
(3,026 Views)
