LabWindows/CVI
Is there a way to query whether a visa alias exists?
I have software that can use one of two instruments. I would like to determine which one is being used by searching for the Visa Alias that is set up in the Automation explorer. Is there a way to query in CVI whether a visa alias is assigned other than trying to use it and waiting for the instrument to error out?
(4,467 Views)
Steve,
I would check out the "Finding Resources" section of the NI-VISA help, it outlines exactly how to do this with C examples.  Here is a short except from there:
"[When] you need to know the exact location (address) of the resource you want to open. To find out what resources are currently available at a given point in time, you can use the search services provided by the viFindRsrc() operation.
Post back if you have any additional questions.
-Marshall R
(4,443 Views)
i can't manage to get resources from their alias name by using the function viFindRsrc(). Can anyone give me an example how to do that?
...if i fill in the alias name (as it is set in the max explorer) for parameter 2 (Expression),
eg. viFindRsrc (Session, "COM1", &FindList, &Cnt, description);
i always get the error that the device can not be found...
(4,026 Views)
That's why VISA resource is named differently: correct syntax is ASRL1::INSTR for COM1.
To find all serial devices in your system you can use viFindRsrc (vH, "ASRL?*INSTR", &list, &count, msg);
Refer to the help for 'Expression' parameter for a detailed description of the syntax name and available possibilities for searching VISA resources.
(4,010 Views)
I know how to get resources by their types... i wanted a way to get resources by their alias, but it seem CVI doesn't support that Smiley Indifferent - on LabView there is an additional parameter for the function wheter to search for aliases: search mode determines how the function returns found interfaces in the find list output, either by canonical names or aliases. The default is 0. --- why is it so difficult to give the same functionality to LabWindows Smiley Frustrated
In addition i found a forum entry: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Does-vifindrsrc-support-alias-names/td-p/3058...
SO, i made a workaround: searching for the given alias in the visaconf.ini and getting the resource type from there, then using viFindRsrc()...
Smiley HappySmiley Tongue
(3,978 Views)
I cannot give you the same functionality of the LV version of viFindRsrc; as a workaround you can use some additional lines to list all visa resources and obtain their aliases: it's a longer route but can be used to locate a specific resource by alias.
These lines can be pasted and executed in the Interactive Execution window:
#include <visa.h>
#include <utility.h>
static ViFindList list;
static char msg[512];
static ViUInt32 cnt;
static ViSession vH;
static int		i;
static ViUInt16 type;
static ViUInt16 num;
static ViChar class[256];
static ViChar unAliasName[256];
static ViChar Alias[256];
viOpenDefaultRM (&vH);
viFindRsrc (vH, "?*", &list, &cnt, msg);
viParseRsrcEx (vH, msg, &type, &num, class, unAliasName, Alias);
DebugPrintf ("%d resources found\n", cnt);
DebugPrintf ("1: %s (%s)\n", msg, Alias);
for (i = 1; i < cnt; i++) {
	viFindNext (list, msg);
	DebugPrintf ("%d: %s (%s)\n", i + 1, msg, Alias);
On my laptop it gives the following output:
3 resources found
1: ASRL1::INSTR (COM1)
2: ASRL3::INSTR (COM3)
3: ASRL5::INSTR (COM2)
(3,946 Views)
