LabWindows/CVI
LABVIEW OF GPIB CAN BE USED FOR RS 232
hi i am quite new in this field. i am working on room temp. AFM, i want  to use external amplifier and wave genertor(wavetek 395) with the current AFM setup, for getting the P-E hysteresis loop, but i have not the lab view program for that SETUP. so what should i do.
so i need  LABVIEW program for  that said setup.
another there is a GPIB (IEEE-488) and Rs 232 as an interface/ports for the wavetek 395. but GPIB-488 is not working.
IS I NEED DIFFRENT SAMPLE CODE/PROGRAM AND DRIVER FOR EACH OF THESE OF THESE 2 INTERFACE/PORT??
CAN I GET THE SAME RESULT, BY USING CODE/PROGARM OF GPIB-488 FOR RS-232??
ANY DIFFERENCE BETWEEN GPIB-488 AND GPIB-488.2??
NI GPIB-488.2 CODE SUPPORT GPIB IEEE-488 OF THE WAVETEK???
(3,729 Views)
Hi
  1. Readers are not blind, there is no need for bold and capitals throughout your text Smiley Wink
  2. Posting the same question several times will not help, especially if posted in the wrong forum. This one, for example, is for a product called LabWindows/CVI
(3,725 Views)
