LabWindows/CVI
link errors
HI NI,
I have a problem with CVI2010 I want to compiler my project but I get errors,
for my project I run both as Realese and debug the problem it's the same, I use NI- USB, and I already reviewed the file in address C.pinch6.JPGpinch2.JPGpinch3.JPGpinch4.JPGpinch5.JPG
(4,013 Views)
Hi Pablo87,
After checking the information you just sent us, I think the DAQmx library was installed with some errors. Could you tell me if you were able to work with this library before?, And also could you tell me what version of the DAQmx software you are using?, you can find this information at NI MAX, and in the left panel at the slot of Software.
Greetings and I'll be aware for your response.
Fell free to write your messages in English or Spanish.
Guillermo O.
Guillermo Oviedo
R&D Software Engineer
CLA | CTD
(3,915 Views)
