LabWindows/CVI
excel_setproperty
I would like to create an Excel report, with text and data in different cells.  For example:
Voltage: 12.345
Power supply: Agilent 6653A
The excel2000dem.cws shows how to write data to excel.  I'm trying the excel_setproperty command.  It's perfectly OK to write data, but not quite successful to write text.  I've tried different tyes of VARIANTS already.
Please advise
(4,614 Views)
Accepted by topic author Hong_Kong
In case you need to write to a single cell you can use
CA_VariantSetCString (&MyVariant, "Text");
Excel_RangeSetItem (ExcelRangeHandle, NULL, CA_VariantInt (row), CA_VariantInt (column), MyVariant);
On the other hand, to write an array of strings to a column, if this is what you want to do, you can use this function:
// Function ArrayTransfer ()
/// HIFN ArrayTransfer ()
/// HIFN Transfer a one-column array to an Excel sheet
/// HIRET Error code (0 if all is OK)
/// HIPAR column/The column to write to
/// HIPAR nRows/Number of elements in the array
/// HIPAR MyVariant/Working variant
/// HIPAR ExcelWorksheetHandle/Handle of the sheet to write to
/// HIPAR ExcelRangeHandle/Handle of the range of cells to write
/// HIPAR aType/Array datatype
/// HIPAR array/Data to trasfer
int ArrayTransfer (int column, int nRows, VARIANT MyVariant, CAObjHandle ExcelWorksheetHandle, CAObjHandle *ExcelRangeHandle, unsigned int aType, void *array)
	int		error = 0;
	char	msg[64];
	if (column > 52)		// In case of 53+ columns
    	sprintf (msg, "B%c2:B%c%d", 64 + column - 52, 64 + column - 52, nRows);
    else if (column > 26)	// In case of 26+ columns
    	sprintf (msg, "A%c2:A%c%d", 64 + column - 26, 64 + column - 26, nRows);
    else
    	sprintf (msg, "%c2:%c%d", 64 + column, 64 + column, nRows);
    errChk (CA_VariantSetCString (&MyVariant, msg));
	if (*ExcelRangeHandle) errChk (ClearObjHandle (ExcelRangeHandle));
    errChk (Excel_WorksheetRange (ExcelWorksheetHandle, NULL, MyVariant, CA_DEFAULT_VAL, ExcelRangeHandle));
	switch (aType) {
    	case CAVT_CSTRING:
			errChk (CA_VariantSet2DArray (&MyVariant, CAVT_CSTRING, nRows, 1, (char *)array));
			break;
		case CAVT_DOUBLE:
			errChk (CA_VariantSet2DArray (&MyVariant, CAVT_DOUBLE, nRows, 1, (double *)array));
			break;
		case CAVT_INT:
			errChk (CA_VariantSet2DArray (&MyVariant, CAVT_INT, nRows, 1, (int *)array));
			break;
	errChk (Excel_SetProperty (*ExcelRangeHandle, NULL, Excel_RangeValue2, CAVT_VARIANT, MyVariant));
Error:
	return error;
The function can be called this way:
int		i, error;
int		nRows;			// Number of elements
char	**dh = NULL;
VARIANT	MyVariant;
// Allocate memory for strings
dh = malloc (nRows * sizeof (char *));	// Data/ora registrazione
for (i = 0; i < nRows; i++) {
	dh[i] = malloc (50 * sizeof (char));
// Fill string array
// Write to the Excel sheet
error = ArrayTransfer (column, nRows, MyVariant, ExcelWorksheetHandle, &ExcelRangeHandle, CAVT_CSTRING, dh);
// Test error code
// Code follows here
(4,604 Views)
