LabWindows/CVI
LIN bus from CVI
Hello all,
i'd like to get started on using Local Interconnect Network (LIN) from CVI. In particular with a NI USB-8476S card. I could not find any sample code offhand, and in MAX it does not appear I can simulate this card (or similar).
Any feelers on how to get started ? I guess I'll go ask questions in the Automotive forum as well !
(3,412 Views)
Accepted by gdargaud
first of all, USB-8476S card is next to its end-of-life.
USB-8506 is recommended as a device.
Then you need to installl NI-XNET driver (you should find this into the DVD shipped with the device).
Afterward you can see LIN under MAX and you can have some tools too.
How Can I Monitor a CAN, LIN, or FlexRay Bus Using NI-XNET?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,193 Views)
Thanks, I didn't know it was part of XNet. I managed to run some of the LIN examples for CVI.
(2,850 Views)
