LabWindows/CVI
Lab windows UI for frequency response
How do i create an UI for the below code
#include <visa.h>
#include <ansi_c.h>
#include <cvirte.h>
#include <userint.h>
#include "stepresponse.h"
#include "toolbox.h"
static int panelHandle = 0;
#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_DEPRECATE)
#define _CRT_SECURE_NO_DEPRECATE
#endif
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "visa.h"
#include "utility.h"
static ViSession defaultRM;
static ViSession instr;
static ViSession instr2;
static ViStatus status;
static ViUInt32 retCount;
static ViUInt32 writeCount;
static unsigned char buffer[100];
static unsigned char buffer2[100];
static char stringinput[512];
static double knobval[512];
static char komand[512];
static double Save[1001];
// Global variables
int f;
double x;
int i;
double j;
int k=0;
double n;
double stepval;
double pointval;
double pval;
double sval;
double g;
double slideval;
int radioButtonVal;
int main (int argc, char *argv[])
status = viOpenDefaultRM(&defaultRM);
status = viOpen (defaultRM, "device address", VI_NULL, VI_NULL, &instr);
status = viOpen (defaultRM, "address", VI_NULL, VI_NULL, &instr2);
status = viSetAttribute (instr, VI_ATTR_TMO_VALUE, 5000);
status = viSetAttribute (instr2, VI_ATTR_TMO_VALUE, 5000);
if (InitCVIRTE (0, argv, 0) == 0)
return -1; /* out of memory */
if ((panelHandle = LoadPanel (0, "stepresponse.uir", PANEL)) < 0)
return -1;
DisplayPanel (panelHandle);
RunUserInterface ();
DiscardPanel (panelHandle);
return 0;
// UI callback function prototypes
/// HIFN Exit when the user dismisses the panel.
int CVICALLBACK panelCB (int panel, int event, void *callbackData,
int eventData1, int eventData2)
if (event == EVENT_CLOSE)
QuitUserInterface (0);
return 0;
int CVICALLBACK OkCallback (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
switch (event)
case EVENT_COMMIT:
// comand for gr initialisation
strcpy(stringinput,"*IDN?");
status = viWrite (instr, stringinput, strlen(stringinput), &writeCount);
// read data from gr 'instr' to variable 'buffer'
status = viRead (instr, buffer, 100, &retCount);
printf("Data read: %s\n",buffer);
// comand for mulmr initialisation
status = viWrite (instr2, stringinput, strlen(stringinput), &writeCount);
// read data from mulmr 'instr2' to variable 'buffer2'
status = viRead (instr2, buffer2, 100, &retCount);
printf("Data read: %s\n",buffer2);
//SET MULTIMETER
strcpy(stringinput, "CONF:VOLTage:AC");
// set channel 1 of GENERATOR to function sin
strcpy(stringinput,"SOUR1:FUNC SIN");
//use knob to set amplitude from GENERATOR
GetCtrlVal(panel,PANEL_NUMERICKNOB,knobval);
sprintf(komand,"SOUR1:VOLT %f",*knobval);
strcpy(stringinput,komand);
//use knob to set MIN frequency from GENERATOR
GetCtrlVal(panel,PANEL_NUMERICKNOBFREQ,knobval);
sprintf(komand,"SOUR1:FREQ %f",*knobval);
//set MAX value
GetCtrlVal(panel,PANEL_NUMERIC_3,&slideval);
g=slideval;
GetCtrlVal (panelHandle, PANEL_RADIOBUTTON, &radioButtonVal);
if (radioButtonVal == 1) {
//Input step value
GetCtrlVal(panel,PANEL_NUMERIC, &stepval);
sval=stepval;
n=sval;}
else
//Input point number
GetCtrlVal(panel,PANEL_NUMERIC_2, &pointval);
pval=((g - *knobval)/pointval);
n=pval;
j = *knobval;
for (f=j,k=0; f<=g; f+=n,k++)
sprintf(komand,"SOUR1:FREQ %f",(double)f);
//DELAY!!!
Delay (0.1);
//READ FROM MULTIMETER
strcpy(stringinput, "MEASure:VOLTage:AC?");
printf("Amplitude read: %s", buffer2);
//save to array
x = atof(buffer2);
Save[k] = x;
//Display Output
printf("Result:\n");
putchar('\n');
for (i=0; i<k; printf("%3.1lf ",Save[i++]));
putchar('\n');
//sinepattern (100. Save[k], 180.0, 2.0, sine);
PlotY (panelHandle, PANEL_Output, Save, k, VAL_DOUBLE, VAL_THIN_LINE, VAL_EMPTY_SQUARE, VAL_SOLID, VAL_DASH, VAL_RED);
//printf("Closing Sessions\nHit enter to continue.");
// session closing
//fflush(stdin);
//getchar();
//status = viClose(instr);
//status = viClose(instr2);
//status = viClose(defaultRM);
break;
case EVENT_RIGHT_CLICK:
break;
return 0;
int CVICALLBACK QuitCallback (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
// session closing
fflush(stdin);
getchar();
QuitUserInterface(0);
break;
break;
return 0;
int CVICALLBACK amplitudeCTRL (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
break;
break;
return 0;
int CVICALLBACK frequencyCTRL (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
break;
break;
return 0;
int CVICALLBACK MaxFreqCallback (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
break;
break;
return 0;
int CVICALLBACK StepToggleCB (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
SetCtrlVal (panelHandle, PANEL_RADIOBUTTON_2, 0);
SetInputMode (panelHandle, PANEL_NUMERIC, 1);
SetInputMode(panel, PANEL_NUMERIC_2, 0);
break;
break;
return 0;
int CVICALLBACK PointToggleCB (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
SetCtrlVal (panelHandle, PANEL_RADIOBUTTON, 0);
SetInputMode(panel, PANEL_NUMERIC, 0);
SetInputMode (panelHandle, PANEL_NUMERIC_2, 1);
break;
break;
return 0;
(4,352 Views)
Where does the code come from? It already has instructions for driving controls on a panel, so I suppose the .UIR file should be included in the packet the code comes from.
(4,310 Views)
Respected Sir,
   The task for me is to construct the UI for this code. As I don't know the basics of this lab window I m writing in this forum
(4,305 Views)
Who passed you the code? Is it a school / training task?
The best solution I can give you is to go through the getting started manual and learn CVI basics so that you understand how panels / controls are treated by the IDE and next go through your code and build the appropriate set of controls in your UI.
An alternative is to attend some CVI course either on line or in class.
(4,301 Views)
