LabWindows/CVI
Visa time out error
Hello.
Is there any solution to avoid visa timeout error ?
I try to configure timeout to 4000 ms but the error appears again
In my program I open connection to R&S instrument, then in the end I close connection to the instrument.
I found that the returned values after closing is error.
I make connection in several threads at time.
Each thread has his unique handle visa but always error timeout.
Should I change ni visa version ?
What about visa buffer ?
Please I need your help
Thanks a lot.
(3,406 Views)
No one can help ! !!!!!
(3,353 Views)
Discussion follows here
(3,338 Views)
