LabWindows/CVI
LabWindows/CVI 9.0 base linking winspool.drv
Hi all,
I use the PrintTextFile function to print messages and would like to warn users if for whatever reason the printer does not print.  I have some code that check for printer error but I have to use windows SDK.
I notice that CVI base does not come with Win32 API's.  I have installed Windows SDK from Microsoft and linked the winspool.lib library to my code.  The software works great on my machine, but when I install the software on another machine, it complained missing a function from dll library and quits.  (Don't remember the exact error message now).
Is this a windows related error or CVI linking error?  Can I link dll library from Windows SDK?
Thanks in advance,
YL
(3,672 Views)
The code is already compiled, so it's not a linking error.  What is the exact error message?
On the development machine, you can check which dependencies are being loaded by setting a breakpoint in your code and going to Window»Modules. Check if those DLLs exist on the target machine.
Mark E.
(3,632 Views)
Accepted by YL_2009
I get this error "The procedure entry point RegisterForPrintAsyncNoticifations could not be located in the dynamic link library WINSPOOL.DRV".
When I was checking for dependencies on my development machine, I did not see any other DLL loaded up other than my executable.  I dig a little and found out that I added winspool.lib into my executable.  When I removed this library from my executable, the error went away.
Thanks Mark.
YL
(3,617 Views)
