LabWindows/CVI Core 1 Course On Demand
I have purchased the Lab/Windows CVI Core1 Course and notice in the very beginning it stating the course will require a BNC-2120, wires, and cable, GPIB interface, NI Instrument Simulator, as well as a CD which contains exercises and solutions. Am I missing something, as I was not send a file that contains any of these exercises, nor was I notified I would need hardware to do the course. It also mentions a Course Manual that I also did not receive or do not know how to locate. Is it fairly easy and cheap to acquire the above hardware? Thank you for your time and my apologies if this is the wrong spot to post this.
Best,
Anthony
(1,669 Views)
Accepted by topic author ajbristow
This was more than a little annoying to figure out, but if you click the "x" in the upper left corner to close the lesson then it will change to a Menu button. That will get you to this menu from which you can download a zip file containing the exercises, solutions, and a PDF of the exercise guide.
FWIW, I haven't completed the course myself yet, but I think you will only need that stuff for a couple of sections and skimming through the exercise guide it looks like at least some of the steps in those sections have alternate instructions for using a simulated device.
(1,609 Views)
