LabWindows/CVI
LabWindows tcp client lost connection with a visual studio server when the window make other operations
I have an application LabWindows/cvi with a main window with menus and buttons.
This main window has a software module that is a client of a TCP/IP connection where the server is in another application created in Microsoft Visual Studio 2019. The name of the server is "SC".
When I select a menu of the main LabWindows/cvi window and I left the menu open without selecting an item menu, the client TCP/IP stop receiving message from the server, while the server send correctly the messages.
I attach the software module that is a client of a TCP/IP connection writed in C in LabWindows/cvi
The LabWindows/cvi application with the main window and the server TCP/IP application are executed in the same PC.
(976 Views)
hello
in the ClientSCTCPRead() func you have a while loop that attempts to read continuously from TCP.
Try To add somewhere ProcessSystemEvents() in the loop
(946 Views)
Accepted by topic author dorianp69
Unfortunately in your scenario ProcessSystemEvents will not solve your problems. As you can read here,
when ProcessSystemEvents handles an event that starts a tracking loop, such as the user pulling down a menu, ProcessSystemEvents does not return until the tracking loop completes. In the case of pulling down a menu, the tracking loop does not complete until the user dismisses the menu.
The usual way to address this kind of issues is to move to a multithreaded framework that guarantees that spawned threads can continue working independent from UI happenings. UI timers are affected by this issue as well so they are not the soution: only asynchronous timers and threads are guaranteed to work.
(941 Views)
Thank you Roberto for the reply,
I solved the problem creating a separate thread that manage the tcp client connection. I use the tcp/MultiThreadingClient.prj sample.
Thank you and Best Regards
(900 Views)
