02-17-2009 05:15 PM
Looking for code examples to measure pulsewidth (5volt pk, 100us ) using PXI-6070E Dev2 "ACH0" and display results in Edit text box. For stable results, do I need to trigger on another channel?
Chris
02-18-2009 01:35 PM
Hello Chris,
Thank you for posting to the NI Forums. The best method for finding example code is to access the Example Finder within CVI (Help>>Find Examples). With the NI-DAQmx driver installed, you will be able to open pulse width examples by clicking Hardware Input/Output>>DAQmx>>Counter Measurements>>Period or Pulse Width. There are two Pulse Width Examples listed there.
I'm not sure what you mean by "stable results." If you would like to elaborate on that, I would be happy to help. Have a great day!
02-19-2009 07:46 AM - edited 02-19-2009 07:55 AM
Hi Margaret,
Thank you!
What I’ve meant by stable results; is the accuracy on catching the rising edge of single pulse.
Test: Start ___2secs____| pulse |_ Stop
Best Regards,
Chris
02-19-2009 07:52 AM
02-20-2009 04:16 PM
Hello Chris,
I think that obtaining stable results will not be an issue with the example that I suggested. Give it a try and let me know if you have problems. Have a great day!
