LabWindows/CVI
Labwindow test software user account on test set.
 I need to set up account for user account with restriction.  User account is  unable to edit test software code and unable delete test reports. User can use test software to run test (test sewuwence) only.
David Huynh
(4,510 Views)
I don't believe there is a way to set user permissions directly in CVI.  However, based on your question, it sounds like you may be using or calling into TestStand.  Is this the case?  If so, TestStand does have the ability to set user privileges.  More information on that can be found here:
https://www.ni.com/docs/en-US/bundle/teststand/page/privileges.html
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/user-and-group-privileges.ht...
(4,485 Views)
