LabWindows/CVI
Display *image in my panel
Hello all again ...
Can I display an acquired ImageBuffer with imaqCreateImage directly in my application panel ???
thanks for all ...
(5,142 Views)
I've never used IMAQ with CVI but you should find an answer to your question here :
http://www.ni.com/pdf/manuals/371266e.pdf
Page 2.7 (chapter "Display an image") should help you...But as far as I understand this document, imaqCreateImage() is not supposed to display any image : this function just returns an image reference you can use when calling other NI Vision functions.
(5,109 Views)
You can use imaqDisplayImage(), but it will display in its own window.
(5,092 Views)
yes, I use imaqDisplayImage(), too, but this function display my image in a new window, but I need displaying the image in my application panel.
It's possible?
thanks again
(5,074 Views)
Theoretically, you could convert the image using imaqImageToArray and then use NI-IMAQ functions such as imgPlot to display it anywhere within any panel.
(5,065 Views)
