LabWindows/CVI
tdm
What are the first three bytes of a .tdm file ? what is its file signature ???
(4,890 Views)
A TDM file is an XML file where it's first bytes are the standard xml intro:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
So detecting a TDM file by the first three bytes is not possible, becausse the same XML preamble can be contained in any XML file.
To detect wether this is a TDM file or not, at least the model section needs to contain the TDM data model:
  <usi:model modelName="National Instruments USI generated meta file" modelVersion="1.0">
    <usi:include nsUri="http://www.ni.com/DataModels/USI/TDM/1_0"/>
  </usi:model>
You may use a XML tool to extract that information....
(4,879 Views)
Much thanks for your immediate reply.
(4,864 Views)
