LabWindows/CVI
Labwindows "Create File" popup?
Labwindows has a "Select FIle" popup dialog in which a user can select an existing file and in addition create a new folder. Is there a similar popup method which allows a user to create a new file at a specific location by navigating to it? Unless I'm not seeing something, it appears that one must create a custome dialog box to do this. Does anyone have any examples or comments?
Doug Wendelboe
(4,682 Views)
FileSelectPopup allows you to enter a new file name if the button label is "Ok": it does not create the file but allows you to enter a filename that does not actually exists in the selected directory. To actually create the filename you will need to use file utilities like fopen.
If the button lable is "Select" or "Save" you receive an error if you input a non existing filename.
(4,678 Views)
FileSelectPopup does allow the user to browse to a directory and then manually input the name of a nonexistent file. You just have to make sure you pass VAL_OK_BUTTON or VAL_SAVE_BUTTON for the button label parameter (as opposed to VAL_SELECT_BUTTON or VAL_LOAD_BUTTON). If you pass either of the latter, the dialog requires the user to specify an existing file.
This doesn't seem to be documented. I'll make sure that point gets added to the documentation.
Mert A.
(4,677 Views)
Thanks to both for your responses. They were what I was looking for.
Doug Wendelboe
(4,672 Views)
