LabWindows/CVI
Set LV window always on top LV8.5
Howto set a LV window always on top? I read a lot of articles but the file isnt available anymore (Winutil.vi) and isnt compatible with 8.5. Are there other options to do this?
B Bakels
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(3,888 Views)
I would suggest posting this question in the LabVIEW forum, it might get better audience there.
http://forums.ni.com/ni/board?board.id=170
Hope this helps.
LDP
(3,877 Views)
Hello Bart,
I agree that in the future you could better post LabVIEW questions in the LabVIEW forums. but anyway, I did take a look at your problem. I found the uttility VI's (I used them a lot in the past) and at least the libraries I found work for me in LaBVIEW 8.5. It could be that you got hold of a VI or llb that was written in a LV version pre 6. These VI's cannot be opened anymore in LV 8.5 and need to be saved first in a higher version. Just to be sure I have mass compiled the LLB's for you. Attached you will find a zip file containing an example program called test.vi (sorry for the not very original name Smiley Happy ) which use two VI's from the WINUTIL.llb. The first VI makes the VI always on top and the last vi revokes this action.
Hope this helps,
Rik Prins - National Instruments Applications Engineering Netherlands
Message Edited by RikP on 06-19-2008 09:38 AM
Rik Prins, CLA, CLED
Software Development Engineer
(3,850 Views)
Sorry, stupid mistake...
Thanks, for the answer
Ik was niet echt wakkker het moment dat ik dit poste 😉
Promedes and DSM
(3,842 Views)
Kaffee hilft. 😉
LDP
(3,831 Views)
