Hello Dave,
To further isolate when this problem occurs, can you open a shipping example in CVI, then set your computer to hibernate? When you recover from hibernation, do you still see the hanging behavior? Also, if you just open an empty workspace, and then hibernate with that workspace open, do you still see the same behavior? If not, then it seems like the problem only occurs when the project that is communicatiing with your external hardware is opened in CVI. So do you know if the driver for you hardware support hibernation?
Let me know how this goes. Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
