LabWindows/CVI
LaunchExecutableEx LE_HIDE make visible
i have written a program that starts different exe-files with the
LaunchExecutableEx function. The windowState is set to LE_HIDE.
Sometimes i need to make the window of the exe file visible. How can i make
the runnig program visible from within the program that started the exe
using LaunchExecutableEx , after it startet with the parameter LE_HIDE?
Thanks for any help
Norbert
(4,163 Views)
Hi Norbert,
my understanding of your issue is that you want to control the visibility of a stand-alone LabVIEW application with an external programm.
Controlling FP visibility within LabVIEW is fairly easy. Use a property node with FP:Transparency and set it to 100 for invisibility an 0 for full visibility.
You can communincate from external programs with your LabVIEW stand-alone application by several means. TCP communication is probably easy to establish. You could also use ActiveX.
Regards, Topp
(4,131 Views)
Thanks Topp,
yes, i want to control the visibility of a stand-alone exe (CVI, not Lab
View) from an external program. I can start the exe with the
LaunchExecutableEx function so that the stand-alone exe is not visible on
startup. But i don't see how its possible to make the stand-alone visible
from within the starter program without any communication between the two
applications....
So i used shared memory to communicate between the two applications because
i don't see that i can show and hide a stand-alone exe from another
application without any communication 😞
Norbert
"Topp" <x@no.email> schrieb im Newsbeitrag
news:1268919626337-1093749@exchange.ni.com...
> Hi Norbert, my understanding of your issue is that you want to control the
> visibility. You can communincate from external programs with your LabVIEW
> easy to establish. You could also use ActiveX. Regards, Topp
(4,119 Views)
Hi Norbert,
please take a look at the following documents:
Launch CVI-created program minimized from within other CVI program:
http://forums.ni.com/ni/board/message?board.id=180&message.id=43247&requireLogin=False
How Can I Launch and Control Another Application in LabWindows/CVI?
http://digital.ni.com/public.nsf/allkb/78B69EED4C66FBAD8625750700408B17?OpenDocument
BTW: Functions for controlling the window-behaviour will you find in the Win32-API.
http://msdn.microsoft.com/en-us/library/ms997562.aspx
I hope this will help you out.
With best reagards,
Ralf N.
(4,106 Views)
