LabWindows/CVI
Re-install of Labwindows contains an DLL load error
I am trying to re-install LabWindows 7.1.1.  After installation, everytime I try to use the library, I get at least 2 or 3 messages that state Automation Support DLL not found.  After that, the routine works correctly.  Anybody know what I lost?
(3,257 Views)
David,
What is "the library" you are trying to use?
Do you know which line of code (which function call) generates the error?
What is the exact error message?
Maybe this or this link may help you a little. All I could find from NI Search.
S. Eren BALCI
IMESTEK
(3,244 Views)
Right now, it is the user interface, however I have not tried any of the other library functions yet.  This occurs when I attempt to get the dialog box up for the function.
(3,205 Views)
