Least square fit in the Advanced Analysis library
Hello all,
I'm a little rusty when it comes to fitting a function to data, and the
GenLSFit function is intimidating ! And unfortunately doesn't come with an
example.
Say I have a 1D array Y[..] containing data of the form
exp(-i/t).(a.sin(M.i)+b.cos(M.i))
I'm looking for a and b (I already know t and M).
First question:
- do I have to use GenLSFit or can I use of of the simplified forms like
LinFit and Co (this function is obviously not linear in 'i') ?
- What do I need to feed GenLSFit ? The first parameter should be a 2D
matrix. Where does that come from and where do my Y array and my function go
Guillaume Dargaud
http://www.gdargaud.net/
(3,409 Views)
Hi Guillaume.
I suggest you try either NonLinearFit() or NonLinearFitWithMaxIters() from the Advanced Analysis Library.
According to the function help, GenLSFit() finds "...the best fit k-dimensional plane ...", i.e. it appears to be suitable only for linearly related data.
Colin.
(3,388 Views)
> k -dimensional
Thanks, I'd missed that one. Works like a charm.
I'm fitting a function to an array that is very close to the function, so I
thought the convergence would be excellent, but I had to use the MaxIter
feature: with some initial values I get instant convergence and with other
(close) values, after 10 minutes the CPU is still chugging along. I guess it
takes a full mathematical treatise to know why, right ?
Guillaume Dargaud
(3,380 Views)
