LabWindows/CVI
Library function error (NI-DAQmx dynamic link library NICAIU.dll)
Hello everyone,
I have searched for solution, but yet i have not found the right solution. So my problem is that i have been deveopling a program for a NI-DAQ device, which is working without any problem on the developer computer, however when i try to run the executable on a client computer i have the following problem:
When i install the NI-DAQmx driver 16.0, it works. My question is:
Is there a way to use the programm i have made, which uses the DAQmx device, without installing the DAQmx driver? Is it possible to just include the neccessary .dll files in the executable? I hope someone can give me any advice.
Thank you in advance!
(3,818 Views)
Accepted by Kugelkopf
To make sure that all files needed to run your executable on another machine you have to make a distribution and install it on the machine you want to run the executable.
See here how you can deploy an application:
https://www.ni.com/docs/en-US/bundle/labwindows-cvi/page/cvi/usermanual/distributionoverview.htm
Constantin
(3,771 Views)
