LabWindows/CVI
Library function error (return value == -46 [0xffffffd2]). The attribute passed is not valid , -> Button Backround Colour cannot be changed
I got this errormessage while executing  my application ,
Code :
SetCtrlAttribute (PanelHandle_2, PANEL_2_COMMANDBUTTON_3, ATTR_LABEL_BGCOLOR, VAL_DK_RED);
I took the attibute value out of the offered list .
Any ideas why my smart button may not become red?
Thank you
Beethoven
(6,903 Views)
This is probably because the panel containing your button is set to be conform to the system colors. You can solve this by disabling this attribute:
SetPanelAttribute (pnlHandle, ATTR_CONFORM_TO_SYSTEM, 0);
If you are using CVI8.1, it might also be that the panel (and thus also the button) are automatically adjusted to the Windows System Theme. So you should also solve this:
SetCtrlAttribute (pnlHandle, PNL_BUTTON,  ATTR_DISABLE_PANEL_THEME, 1);
(6,902 Views)
Thanks a lot for the quick response.
I implemented  the first hint , but the result was the same error message as before.
When trying to implement  the second hint , I got an error box when inserting the function panel text , because
ATTR_DISABLE_PANEL_THEME   is not known in CVI 8.0.1.
For the moment I can only change the LabelText Coulour, what should be sufficient for my application .
(6,893 Views)
The attribute you listed in your code was for the label; perhaps you meant to use the one for the command button itself?
    SetCtrlAttribute (PanelHandle_2, PANEL_2_COMMANDBUTTON_3, ATTR_CMD_BUTTON_COLOR, VAL_DK_RED);
JR
(6,891 Views)
Hello JR ,
your solution was great. I checked the  code  and found exactly that mistake.
Thanks a lot and greetings to wherever you are.
Beethoven
(6,885 Views)
Hi, there is my question: Library function error (return value == -46 [0xffffffd2]). The attribute passed is not valid
 and the code :   SetCtrlAttribute(ciCVIPanel, ciCVIControl, ATTR_TEXT_POINT_SIZE, 10);
would you please help me check it? i have no idea about this issue.
(5,949 Views)
The error says all: you are addressing an attribute which cannot be operated on the control type you are using. It all depends on which control is pointed to by ciCVIControl variable.
A good option to know the attributes that can be use on a single control is to right-click on the control and select Control help: in the window that shows, select Control Attributes link and you will see a list of all valid attributes for that control type.
Alternatively, right-click on SetCtrlAttribute instruction and execute Recall function panel function (or press Ctrl+P) and click on Control attribute field: Select Attribute Constant dialogue will show where you can select the control type you want to operate on in the list on the left: in the right pane valid attributes only will be shown.
As a last note, it would be better in the future to open a new discussion instead of reviving a very old thread with a question that is only marginally related to it.
(5,945 Views)
