LabWindows/CVI
create CVI DLL to be called in LUA
Hello everyone,
I am a LabVIEW user and new to LabWindows. Currently, I have to plan a project which needs to integrate software in different languages.
The situation is that I have one LabVIEW vi needs to be integrated into a HMI which is written in LUA. I am now thinking is it feasible to first convert LabVIEW vi or project first into CVI DLL and than call it in LUA. Does anyone have some experince/ advices about it? I found it is possible to using LUA in LabVIEW with LuaView. How about the other way round?
Any pointer will be highly appricated.
Cheers,
sparkle
(4,038 Views)
Accepted by topic author sparklexiong
I am Ed from National Instruments Applications Engineering. I have been forwarded your query which I am happy to assist you with.
I believe the following article should provide you with the necessary steps to develop a DLL from a LabVIEW project:
http://digital.ni.com/public.nsf/allkb/A3804F88FCDB1E6286257CE00043C1A7
After which, if LUA is capable of calling C DLL's then you should then be able to use the DLL as you would a C DLL. From which some research outlined you may need a module from the stack overflow page which I have also linked below and also a suggested module to use on this stack overflow page:
1. http://stackoverflow.com/questions/2835716/how-do-i-call-functions-inside-c-dll-from-lua
2. http://www.nongnu.org/cinvoke/lua.html
Ed
(4,010 Views)
