LabWindows/CVI
create CVI DLL to be called in LUA
Hello everyone,
I am a LabVIEW user and new to LabWindows. Currently, I have to plan a project which needs to integrate software in different languages.
The situation is that I have one LabVIEW vi needs to be integrated into a HMI which is written in LUA. I am now thinking is it feasible to first convert LabVIEW vi or project first into CVI DLL and than call it in LUA. Does anyone have some experince/ advices about it? I found it is possible to using LUA in LabVIEW with LuaView. How about the other way round?
Any pointer will be highly appricated.
Cheers,
sparkle
(3,988 Views)
Accepted by sparklexiong
I am Ed from National Instruments Applications Engineering. I have been forwarded your query which I am happy to assist you with.
I believe the following article should provide you with the necessary steps to develop a DLL from a LabVIEW project:
http://digital.ni.com/public.nsf/allkb/A3804F88FCDB1E6286257CE00043C1A7
After which, if LUA is capable of calling C DLL's then you should then be able to use the DLL as you would a C DLL. From which some research outlined you may need a module from the stack overflow page which I have also linked below and also a suggested module to use on this stack overflow page:
1. http://stackoverflow.com/questions/2835716/how-do-i-call-functions-inside-c-dll-from-lua
2. http://www.nongnu.org/cinvoke/lua.html
Ed
(3,960 Views)
