ListBox string character sizing
I have a list box that contains strings up to 80 characters long.
I have to size the listbox width in the uir to be wide enough for 80 characters.
Any 80 numerical character combination is a constant legth, however, letters show up as different sizes and some are longer and some are shorter.
Is there a way to force all string characters to occupy the same width?
(3,948 Views)
You can edit the listbox in the UIR editor and apply a non-proportional font to the control (look in "Text style" button in listbox options): choose among the fonts available on your system the one that you prefer, considering that you may have problems if chosen the font is not available in the target system. In my system the following non-proportional fonts are available: Courier, Courier New, FixedSys, Lucida Console, NIEditor and NISystem: I think the majority of them are standard fonts, available on all systems.
(3,928 Views)
Accepted by NI Nubie
Thanks you rule, AGAIN!
Brad.
(3,903 Views)
