LabWindows/CVI
ListGetItem question (from toolbox.h)
Hello all,
If I get an element pointer from a list with ListGetItem(), can I assume
that it stays valid while I keep inserting/deleting _other_ elements to the
list ?
Guillaume Dargaud
http://www.gdargaud.net/
(3,547 Views)
Well, it looks like I misunderstood. I thought ListGetItem() returned a
pointer to the inside of the list, when it's just a copy. So that won't
work.
I need to keep pointers to some elements of my list, even while the list is
being manipulated. Suggestions unless I reimplement it myself ?
Guillaume Dargaud
(3,546 Views)
I would think that ListGetPtrToItem or ListGetDataPtr would address your problem, but the documentation clearly states that they are only valid until the list is modified, so they won't survive list manipulation. Moreover, the documentation for the latter states that "items are stored (in memory) contiguously in ascending order": it appears that manipulating the list alters this order so that getting a valid pointer is not possible unless you perform a new list search.
(3,540 Views)
Yup. I decided to use the List* functions, but more intelligently: calling
when needed instead of using pointers.
Those functions are really handy. It's too bad that a lot of my code is not
in CVI but just standard C. I wish there were list functions in standard C.
Or source code from NI to recompile at willl... 😉
Guillaume Dargaud
(3,517 Views)
Guillaume Dargaud
Code for toolbox instrument is available in <cvidir>\toolslib\toolbox: don't know if it is possible to recompile all or part of it for use under Linux OS.
(3,514 Views)
