LabWindows/CVI
Minimize user interface
I am using CVI 8.5 and having the same issue as stated here.
That is when the minimize button is selected User Interface will not come back up and the application is requred to be killed.
The workaround suggested in the post did not work either:(
Is there a way to gray out the minimize button on the CVI Full feature Operator Interface when the sequence is executing? If the sequence is not executing the minimize button is enabled.
Thanks.
CLD
(3,617 Views)
Does the fix suggested by Yves here work for you?
I had the same problem in the past, and this works for me
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,609 Views)
I have found that this problem disappears if the panel titlebar isn't visible. See here for a short description of this workaround.
(3,600 Views)
