LoadMenuBar and "Embed Project .UIRs"
It seems that it in not possible to load a menuebar directly from an embedded UIR!
Any comments?
Babak
(3,522 Views)
Hello baki,
If you are using CVI 7.0 or earlier, check out the following discussion forum post.
This issue has since been fixed for CVI 7.1. I ran your code in CVI 7.1 and the menubar was correctly embedded.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(3,513 Views)
Is it possible to work with the CVI 7.1 runtime and the 7.0 programs?
Babak
(3,507 Views)
Hello Babak,
The CVI runtime engine is backwards compatible and will work with your CVI 7.0 programs. I have tested your program with CVI 7.0 and CVIRTE 7.1 and it seems to work as expected.
Thanks.
Wendy L
(3,499 Views)
