04-08-2005 11:56 AM
04-08-2005
01:35 PM
- last edited on
07-08-2025
02:51 PM
by
Content Cleaner
Hello baki,
If you are using CVI 7.0 or earlier, check out the following discussion forum post.
This issue has since been fixed for CVI 7.1. I ran your code in CVI 7.1 and the menubar was correctly embedded.
Thanks.
04-10-2005 02:24 AM
04-10-2005
10:23 AM
- last edited on
07-08-2025
02:52 PM
by
Content Cleaner
Hello Babak,
The CVI runtime engine is backwards compatible and will work with your CVI 7.0 programs. I have tested your program with CVI 7.0 and CVIRTE 7.1 and it seems to work as expected.
Thanks.
