LabWindows/CVI
Log multiple data channels at different rates using TDMS?
I need to log a large number of data channels that are sampled at different rates. The data are sampled by multiple cRIO-9068 data acquisition systems and transmitted over a network to a central Windows system. I propose to log this data in the TDMS format under LabWindows/CVI but I'm uncertain about whether TDMS is designed to handle multiple data rates. Before I go and burn up a lot of time experimenting, can anyone tell me if they've had either success or failure with this?
I've already reviewed the following documents:
The NI TDMS File Format
TDMS File Format Internal Structure
Message 1 of 1
(4,279 Views)
