LabWindows/CVI
Logarithmic Frequency Increment
Does anyone have code for a Logarithmic frequency increment that permits uniform spacing of the data points, given the start and end frequencies along with the number of points?
Any help would be appreciated.
regards,
D
(3,736 Views)
You could try something along these lines:
#include <math.h>      // For the pow() function
    double start;      // eg 10
    double end;        // eg 1000
    double points;     // eg 15
    double select;     // the sample point to calculate, eg from 0 to 14
    double value;      // will receive the logarithmic value of the range, at the selected point
    value = start * pow (end / start, select / (points - 1));
Depending on the rest of the application you might want to add some basic error checking.
JR
(3,711 Views)
