LabWindows/CVI
Runtime Linux
Hello all,
I'm begining to finalize several apps for Linux use and want to distribute
them internally.
I know the LabWindows Linux runtime engine is in the form of an RPM which
pretty much limits the distributions on which it can run. There are ways to
install RPMs onto other distributions. Has anyone tried to convert it to a
..deb, or to unpack for direct installation like on Gentoo ?
In my mind is the option of installing it on embedded systems with
micro-linuxes that won't be rpm-based. Any info about that ?
Guillaume Dargaud
http://www.gdargaud.net/
(4,298 Views)
It is fine to just directly copy the files from /usr/local/natinst/cvirte.  All the rpm does is copy the files, add symbolic links in /usr/local/lib to the newly copied shared libraries and make sure that /usr/local/lib is in /etc/ld.so.conf.
If you are using the analysis library you also need the shared libraries installed by labview-rte-aal-1.1-1.i386.rpm.
Michael
NI
(4,281 Views)
Thx
Guillaume Dargaud
"Computer system analysis is like child-rearing; you can do grievous
damage, but you cannot ensure success." - Tom DeMarco.
(4,266 Views)
