LabWindows/CVI
Look through Sub-directories
I am looking for a source code to be able to do a recursion through a
root directory and its sub-directories to look for every files with the
extension *.htm. I would like to look for each files and modify them if
necessary.
How could I do, please?
Thanks for your help.
Cheers
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(3,129 Views)
I recently wrote a VI that does just that. It searches for a list of file suffixes and writes the paths to a global array of strings. This list could then be pulled up in another part of the program to modify the files.
Please e-mail me and I will reply with the attached files.
[nrolan01@tufts.edu]
- Nate
(3,129 Views)
