LabWindows/CVI
need to hex encode string like escape() function
In java there is the escape() function which replaces all characters other
than letters and numbers with %xx notation. Is there something analogous in
CVI-land?
(3,628 Views)
Hello Willie,
In LabWindows/CVI, the string manipulation functions can be found in either the ANSI C Library or the CVI Formatting and IO Library. I do not recall hearing of such a function in CVI, and after double-checking it does not look as though CVI provides a function that does this. You will either need to write your own escape() routine, obtain one from another vendor, or somehow wrap and link to the escape() Java function. Good Luck!
Jeremiah Cox
http://www.ni.com/ask
(3,628 Views)
I am still not able to get this to work. Here is the function that I wrote to simulate the escape() function. There is a page on the Netscape site that I am testing it against- developer.netscape.com/viewsource/husted_mailto/mailto.html
They encode "<$"%123" into %22%3C%24%22%25123%22. I have written URLencode below to simulate this. I can't even compile when I set pszString="<$/"%123" because I get a missing " error on the last quote. BTW, they set spaces to equal %20, not +.
char szEncoded[200];
void URLEncode(char *pszString)
char szChar[3];
int iChar;
memset(szEncoded,0,sizeof(szEncoded));
j=0;
for (i=0;i {
// don't touch alphanumeric chars
if (((pszString[i]>=48)&&(pszString[i]<=57))||
((pszString[i]>=65
)&&(pszString[i]<=90))||
((pszString[i]>=97)&&(pszString[i]<=122)))
szEncoded[j]=pszString[i];
j++;
continue;
if (pszString[i]==32) //' replace space with "+"
szEncoded[j]='+';
j++;
continue;
//Else
// ' replace punctuation chars with "%hex"
szEncoded[j]='%';
j++;
iChar=pszString[i];
sprintf(szChar,"%x",iChar);
strncat(szEncoded,szChar,2);
j=j+2;
(3,628 Views)
