Looking for 9184/9263/9215 examples
Well, looks like I'm swamping the forum tonight.
I've never used NiDAQmx before, so I'm looking for sample codes in CVI for a cDAQ-9184 with an AO 9263 module and an AI 9215 module. I imagine there are sample code for compatible hardware with different names but after a cursory search using [Help][NI Example Finder] I couldn't come up with anything.
(5,776 Views)
Accepted by topic author gdargaud
The chassis 9184 has no specific software.
If you add the 9215 to the lost of hardware select it and check "Limit resusts to hardware", next search for "analog" you'll find a series of examples that can be run on the module. The same applies for the AO module you have.
(5,762 Views)
I think that examples in "Hardware input and output\DAQmx\" should work with any card(with compatible chanel type - VoltageOut,...). The examples show basic usage of Input/Output task (and chanels).
If you looking for specific configuration of NIDAQmx-task for your card, there is wizard that could help you.  It is in CVI menu: "Tools"\"Create/Edit DAQmx Task" ->"Create New task in project"
There, you can setup your task like in MAX explorer and let the CVI to generate source code for you.
(5,759 Views)
I didn't know about the code generation option. Will try that.
Also I found examples in "C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Exemples\DAQmx ANSI C" but they may be the same mentionned by Roberto.
(5,751 Views)
Which system are you running ON?
On my Win7 machine Documents and settings folder is protected and gives access denied error! Smiley Surprised
Having said this, DAQmx samples can be located with File Explorer in Collections menu (hope the translation is correct: in italia it sounds "raccolte"):
Collections\Documents\Public documents\National Instruments\CVI\Samples\DAQmx
or
C:\Users\Public\Documents\National Instruments\CVI\samples\DAQmx
which is the same.
The example finder simply operates a filter on the samples located there, I suppose.
(5,746 Views)
Still using good old WinXP in virtual machines...
(5,741 Views)
