LabWindows/CVI
Loops through worksheets Excel
I tried to loop through the worksheets in and Excel doc by increasing the work sheet handle. But unfortunately that does not seem to be possible and I got an error.
	ExcelRpt_SetWorksheetAttribute(rawDataWorkSheetHandle,ER_WS_ATTR_NAME,"Analysis Data");
	__caErrChk(ExcelRpt_SetWorksheetAttribute(rawDataWorkSheetHandle+1,ER_WS_ATTR_NAME,"something"));
Is it somehow possible to do that? I don't like haven a handle for every worksheet in my workbook..
Thanks!
(5,062 Views)
Accepted by ZerMahlMeer
Like it or not, you need to get the worksheet handle if you want to access worksheet attributes.
There is a function named ExcelRpt_GetWorksheetFromIndex for that purpose.
This function outputs the worksheet handle if you provide its 1-based index.
Beware that You have to call CA_DiscardObjHandle after you are done with that worksheet.
So both functions above should be inside your for-loop.
S. Eren BALCI
IMESTEK
(5,046 Views)
