LabWindows/CVI
MAX command line parameters
I could program a whole panel to allow the user to modify the setup parameters for a DAQmx task, but decided that it's easer to simply stop the task and launch MAX with LaunchExecutableEx and let the user play with the task settings there. Is there any way to tell MAX, e.g. through command line parameters, to open up and display a particular DAQmx task upon startup?
(4,200 Views)
Accepted by pblase
Helo pblase,
I do not believe that it is possible to configure MAX to open up on a particular task. It also appears that there is no MAX ActiveX Automation Server that we can access.
Jacob R. | Applications Engineer | National Instruments
(4,179 Views)
