LabWindows/CVI
Macros in variable watch view
Hello all,
I'm pretty sure this used to work in 2010.
If I have a macro in a formula, it won't evaluate in the watch window.
For instance, according to iso646 I can have "a and b" in my prog, which compiles fine (#define and &&). But selecting it with Ctrl-F7 returns an error. Editing the formula to replace 'and' with '&&' works. Not critical but annoying.
(5,587 Views)
gdargaud,
What version of LabWindows/CVI are you using? I tried to recreate the behavior in 2013 SP1 but am not seeing the error you described.
(5,552 Views)
using CVI2013sp1:
(5,539 Views)
gdargaud,
thank you for sharing the screenshot. i observed the behavior in 2013 SP1 but not in 2012 SP1. i will file a bug report for this behavior.
(5,516 Views)
Accepted by topic author gdargaud
There is already a bug report for this in the Known Issues list.
(5,469 Views)
It would be good if we could filter the known bug table, for instance filter out all bugs solved before 2013sp1: I've perused it several times but keep getting sidetracked by solved bugs.
(5,434 Views)
