LabWindows/CVI
Multithreading - thread-safe-queue timing
I'm wrting a large data-acquisition and processing program using LabWindows/CVI 2010, Windows XP.
In the data acquistion section, I have a DAQmx task (set up using MAX) that will acquire a number of points, typically 1000 @ 50 kHz, on receipt of a trigger.
After the task is loaded with
  DAQmxLoadTask ("task_name", &DAQTask_Handle);
A handler is installed with
    DAQmxErrChk(DAQmxRegisterEveryNSamplesEvent (DAQTask_Handle,
                                                 DAQmx_Val_Acquired_Into_Buffer,
                                                 PointsToAcq,
                                                 0, //non-synchronous event callback, called from DAQmx thread
                                                 CB_Level1_DataRdy, NULL));
The trigger frequency is supposed to be 30 Hz, so in order for things to happen quickly enough I've already determined that the callback event needs to be non-synchronous. This is what is turning this into a multi-threading exercise.
A threadsafe queue is also set up  with
        status = CmtNewTSQ (DataQueueListSize(), sizeof (float64), OPT_TSQ_DYNAMIC_SIZE, &DataQueueHandle);
A callback (from the receiving module, in another dll) is installed with
         status = CmtInstallTSQCallback (DataQueueHandle, EVENT_TSQ_ITEMS_IN_QUEUE, PointsToAcq, callback_func, NULL, CmtGetCurrentThreadID(), NULL); (where callback_func is the callback routine passed in through a subroutine call. )
The DAQ callback, then looks something like this:
int32 CVICALLBACK CB_Level1_DataRdy (TaskHandle taskHandle,
                                     int32 everyNsamplesEventType,
                                     uInt32 nSamples,
                                     void *callbackData) {
    //set priority
    status = CmtGetCurrentThreadPriority (&Priority);
    status = CmtSetCurrentThreadPriority (THREAD_PRIORITY_TIME_CRITICAL);
    // setup stuff here
    // read data from DAQmx
    DAQmxStatus = DAQmxReadAnalogF64 (taskHandle, DAQmx_Val_Auto, 0,
                                    DAQmx_Val_GroupByChannel,
                                    DataBuffer,   //float64 array large enough to receive the samples
                                    BufferSize, &samplesRead, 0);
    //do some processing here
    status = CmtWriteTSQData (DataQueueHandle,  DataBuffer, samplesRead, 0, NULL);
    //restore thread priority
    CmtSetCurrentThreadPriority (Priority);
So far, so good.Note that the callback above is called from the DAQmx thread; the queue is used to buffer the data with the display, which is accomplished in the main process thread. It was necessary to set the DAQmx thread priority to THREAD_PRIORITY_TIME_CRITICAL to ensure that the handler doesn't get interrupted by later events.
On the other end, the queue callback is defined as
void CVICALLBACK Receiver_DataAcqHandler (CmtTSQHandle queueHandle, unsigned int event, int value, void *callbackData) {
    num_data_read = CmtReadTSQData (queueHandle,
                                    ReceiverVoltsBuffer,
                                    samplesRead,
                                    TSQ_INFINITE_TIMEOUT, 0);
       //get rid of old handle
       if (g_iPlotHandleReceiver) {
           status = DeleteGraphPlot (MainWindowHandle, PANEL_GRAPH, g_iPlotHandleReceiver, VAL_DELAYED_DRAW);
           g_iPlotHandleReceiver = 0;
       //plot data
       g_iPlotHandleReceiver = PlotWaveform (MainWindowHandle, PANEL_GRAPH, ReceiverVoltsBuffer,
                     num_data_read, VAL_DOUBLE, 1.0, 0.0, 0.0, 1.0,
                     VAL_THIN_LINE, VAL_NO_POINT, VAL_SOLID, 1, VAL_GREEN);
This version works nicely. I instrumented the program with some writes to the DAQ card's digital IO lines: the call to the DAQ callback taks about 250 us, being called immediately after the 1000 points have been acquired. No problem. The queue call takes about 5 milliseconds; what's interesting, though, is that you can watch the time-slicer working: the delay from the end of teh DAQ callback to the start of the queue callback varies from 0 to 30 ms, in a regular fashion. It starts out at 30, walks up to 0, then resets to 30 ms.
Question 1: is there a way to control this, so that the queue callback is called immediately? I've tried changing the thread priority, and it did nothing.
If you notice, using this scheme I have to double-buffer the data: DAQ->DataBuffer->queue->ReceiverVoltsBuffer->graph control.
I tried to shorted things up a bit by using the facility to get a pointer into the thread-safe queue. In this case, the queue callback looked like this:
     float64 *F64_data_p;
     status = CmtGetTSQReadPtr (queueHandle, &F64_data_p, &num_data_read);
       //plot data
       g_iPlotHandleReceiver = PlotWaveform (MainWindowHandle, PANEL_GRAPH, F64_data_p,
      //return pointer
     status = CmtReleaseTSQReadPtr (queueHandle, num_data_read);
This doesn't work well at all. In addition to the time-slicer delays, the actual routine can take up to 30 ms. I can only conclude that having the queue checked out for the duration of the PlotWaveform call messes things up somehow.
Question 2: can somebody help me under stand this timing issue? Something obscure is going on here.
(5,559 Views)
Hi pblase,
Can you clarify what the actual issue is here?  Are you getting error messages or losing data?  Since you are using a queue, the timing of the data collection and processing should be decoupled.
Jayme W.
(5,516 Views)
Was this issue ever resolved? I am having a similiar problem using a PCI 6534 and TSQ's
(5,039 Views)
Hi bill.kim,
As the last poster commented, this issue is a little hard to understand.  Could you clarify what your exact problem is?  Is there an error message or lost data?
I would also strongly recommend starting a new thread for your issue, since this thread is relatively old and won't get as much attention.
(5,020 Views)
