LabWindows/CVI
Map in CVI
I would have a question about GPS.
I am currently working with one GPS, where I read geographic longitude, latitude, and altitude data.
And the question is, I would like to draw CVI in a graphical way using a map, for example, from Google and see the movement.
I want to add a map to CVI.
For example, as it appears in the appendix.
Anyone know how to do it?
It would help me a lot.
Thank you for your advice.
I wish you a nice day
(I apologize for my English)
(3,174 Views)
Hi MajklS -
A possibly easy solution for you would be to embed a Microsoft Web Browser ActiveX control in your panel. Then, you can program the ActiveX control to display a Google Maps page.
Check out the userint\activex\WebBrowser sample application on how to achieve this.
I hope this helps!
Kind regards,
- Johannes
(3,138 Views)
Hi Johannes,
thank you for your advice, i didn't know about this example.
I'll look at it and try to use it.
Thank you for help
Nice day
Regards
MajklS
(3,118 Views)
so I managed to insert the map into the program. (See picture)
I have one more problem, the page is updated over and over again when plotting geographic location.
(I have a feature in Timer.)
Do you know how to treat it so that the location shows me when moving, but does not update the page? For example, as it is with a classic mobile GPS.
My listing looks like this:
GetObjHandleFromActiveXCtrl (panelSerial, SERIAL_WEBBROWSER, &webHandle);
Combo_InsertComboItem (panelSerial, SERIAL_ADRESA, 0,
"https://mapy.cz/zakladni");
SetCtrlVal (panelSerial, SERIAL_ADRESA, "https://mapy.cz/zakladni");
GetCtrlVal (panelSerial, SERIAL_LATITUDE, &latitude);
GetCtrlVal (panelSerial, SERIAL_LONGITUDE, &logtitude);
Fmt(mapa, "%s%f%s%f%s%f%s%f", "http://www.mapy.cz/zakladni?x=", logtitude, "&y=", latitude, "&z=17&source=coor&id=", logtitude, "%2C", latitude);
INET_IWebBrowser2Navigate (webHandle, NULL, mapa, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL, CA_DEFAULT_VAL);
//Install event handler for navigate complete event from web browser
INET_DWebBrwsrEvnts2RegOnNavigateComplete2 (webHandle, NavigateComplete, NULL, 1, NULL);
(3,114 Views)
