Showing results forĀ
Search instead forĀ
Did you mean:Ā
Maximum panel width
Hi Luis,
Thanks for your reply.
GetSystemMetrics (SM_CXVIRTUALSCREEN) return 1920
GetSystemMetrics (SM_CYVIRTUALSCREEN) return 1080
They return the setting resolution of my graphic card (the same of my monitor).
Do you have tryed the sample code attached previous?
Message 11 of 15
(1,735 Views)
... for completeness, in my case GetSystemMetrics (SM_CXVIRTUALSCREEN) returns 1600.
Message 12 of 15
(1,732 Views)
Just out of curiosity I made some trials and here are the results.
With this code:
DebugPrintf ("Virtual screen size: %d\n", GetSystemMetrics (SM_CXVIRTUALSCREEN));
GetPanelAttribute (panelHandle, ATTR_WIDTH, &pw); DebugPrintf ("Actual panel width: %d\n", pw); SetPanelAttribute (panelHandle, ATTR_WIDTH, 10000); GetPanelAttribute (panelHandle, ATTR_WIDTH, &pw); DebugPrintf ("Max panel width: %d\n", pw);
I obtained these results:
Virtual screen size: 1680
Actual panel width: 1024
Max panel width: 3354
BTW, 1680 is the actual resolution of my display.
Message 13 of 15
(1,729 Views)
OK,
From my first post I changed the monitor with a full-HD (1920x1080 mentioned above), so my new limit panel width is 3824, exactly twice my current horizontal resolution.
The maximum panel width is twice the horizontal resolution.
Message 14 of 15
(1,726 Views)
Accepted by topic author Biccio
I think the maximum width might also depend on the current position of the panel, but I'm not completely sure.
I'm sorry that I'm not providing exact details on how the maximum width is computed, but the short answer is that I don't know what they are.
Luis
Message 15 of 15
(1,715 Views)
