LabWindows/CVI
May I programme in VC++ to call the menu command of cvi?
May I programme in VC++ to call the menu command(such as File Open,Add Files To Project,Create Dynamic Link Library,etc) of CVI 5.0?
My situation is:(The development tool is VC++6.0, CVI will only appear as a DLL generator in my project.)I want to load cvi.exe only once,but will use it to open project files several times.(I've tried to call system("c:\\cvi\\cvi.exe filename.c"),but each time I open a file,the cvi was reloaded. )And later,I'll control it to generate DLLs.All above must be controlled by programming in VC.
(2,965 Views)
You can do this using the ActiveX server interface to CVI from Visual C++. There is an example of using the ActiveX server to CVI from CVI in the \samples\activex\cvi directory.
Best Regards,
Chris Matthews
Measurement Studio Support Manager
(2,965 Views)
Yes!
That's just what I really wanted.
Thanks a lot for your help!
Lily
(2,965 Views)
