LabWindows/CVI
Measuring pulses riding on dc voltage.
Hello, I have a question regarding measuring triggered pulses using labwindows cvi. I have a TTL pulse riding on a 1Vdc. I am able to measure the TTL pulse using labwindow's triggered pulse library function. how can I verify the 1vdc voltage that the pulse is riding on? can somebody please help me out.
(3,341 Views)
Well, I guess it would depend on what you mean by "verify" but a simple way of looking at the data & seeing if the dc offset is visible is to use the CVI PlotWaveform() call in conjunction w/ a graph control.  Have you tried that already?
Andy
(3,310 Views)
Thanks for the reply Andy,
Yes I was able to display the waveform using niScope call in functions.( I am using NI 5112 scope card 8-bit digitizer 100MHZ 100MS/s). I also have a SCB-68 pin shielded connector Block with a AT-MIO-16E board. I was able to capture a triggered pulse of the waveform using AIAcquireTriggeredWaveforms() function. I was also able to save the samples into a  *.txt file. I can clearly see the 1V dc value in the record. This is the part I need some advice. Would it be valid if I write a simple program to isolate the samples with 1Vdc and take an average(mean) value to justify the 1Vdc voltage of the waveform?
Thank you in advance
CB
(3,270 Views)
Sounds reasonable to me, slash, but maybe some of the more experienced test engineers who frequent this site have other suggestions.  One thing I was wondering about was why you don’t subtract out the 1v offset from your result & plot the fundamental signal to see if it matches the characteristics of a TTL compatible signal in terms of high & low signal levels, rise & fall times, minimum pulse width, etc.  If so, then wouldn’t that be the validation you are seeking?  Then again, maybe I am misunderstanding your problem.....
Andy
(3,257 Views)
