LabWindows/CVI
Measuring value of voltage after a digital edge with time delay
I am new to labwindows.I am developing a data acquisition system for a small particle detector. I need to read the value of the voltage pulse at a set time after recieving a digital trigger pulse. I am working with a ni9205 and a ni9403 (and a cDAQ9174)
I have noticed that the ni9205 has a PFI0 pin that can be used to trigger measurements but I can't find how to delay the measurement upto a specified a time interval after the trigger. Also, I had expected that the ni9403 could be used to trigger the voltage readings given that it is a device specialized for digital measurements, but I have not been able to do that.
Thanks in advance.
(4,421 Views)
This all depends on the duration and precision of the delay you require between the trigger pulse and the analog reading. With the hardware listed, I think you have 3 options:
1. Detect the edge transition and time the delay in software.
2. Use some discrete logic (e.g. HC series TTL) or an FPGA to build a delay circuit that triggers from your trigger pulse, delays a time set by the digital output of the NI9403, and then triggers the NI9205. This will be the most precise method, especially if you use a good quality crystal oscillator.
3. The cDAQ9174 has 4 timer/counters. It is possible that you could do what you want with these, but a close read of the manual, some thought & experimentation will be required.
(4,413 Views)
