LabWindows/CVI
thumb impression system
Hey!  I want to make a thumb impression system in Labwindows/CVI
Is thiss possible to make it using this tool ?
(4,802 Views)
Yes. With programming in C you can achieve almost everything 😉
(4,792 Views)
The question makes no sense, you need to give more detail.
You seem to suggest a software solution to a hardware problem. You cannot "make" hardware using software.
Do you have an existing thumb impression system that you want to control with software?
If the programming interface is documented, you can interact with it using any programming language.
(4,784 Views)
