LabWindows/CVI
Misleading warning on CVI startup: breakpoints and tags have been removed
Just tested in 2015 with a shipping example; breakpoints and tags are not cleared from the .cws after openint the project with a missing file. I see your same behaviour: breakpoint and tags are retained and represented the next time I open CVI with the file present again; I am also warned that they will be cleared, even if they aren't.
I have the Auto Save option set, too.
It is to be said, though, that if I make some modification that implies saving the workspace (e.g. open a new file or close an opened one) taks and breakpoint are cleared, even it the missing file section is still present; reopening the workspace with the file present again will result in breakpoints and tags cleared in that file.
So it seems the warning is not fully misleading: only if no modifications at all are made breakpoints and tags remain in the project, otherwise they are cleared.
Message 11 of 18
(1,252 Views)
Thanks for confirmation, Roberto.
Message 12 of 18
(1,246 Views)
Hello MelanieE,
what about a win-win situation: you provide us a CAR and and talk to your colleague to have it implemented today (before we forget), I provide the solution which seems pretty simple to me:
All that is needed from my point of view is changing the text of the warning pop-up message, from
The file "xyz" was not found. The breakpoints and tags in it have been removed.
to
The file "xyz" was not found. If now you make changes to your project the breakpoints and tags of file "xyz" will be removed.
I think that the latter statement correctly describes the current behavior of CVI.
Message 13 of 18
(1,222 Views)
Hi Wolfgang,
I have not been in office for a while, so sorry for the delay.
I think we have some new points here I need to check on my machine. Give me some time for it, I will update you, if I see the same behavior. If so, we can continue with your win-win sugestion.
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
Message 14 of 18
(1,191 Views)
Hi Melanie,
everyone is permitted vacations Smiley Happy I will be ooo in September Smiley Very Happy So take your time and thanks for coming back!
Message 15 of 18
(1,188 Views)
Accepted by topic author Wolfgang
Hi Wolfgang and Roberto,
I played around with my project a bit more. With the discription from Roberto I was able to see the same behavior as you discribed, Wolfgang.
I will document the behavior the next days and post the ticket number.
Best,
Melanie
Melanie Eisfeld
Message 16 of 18
(1,130 Views)
I reported the behavior today. The tracking number is: 665361
Best,
Melanie
Melanie Eisfeld
Message 17 of 18
(1,121 Views)
Thanks Smiley Happy
Message 18 of 18
(1,054 Views)
