Missing "OK" button label in MessagePopup window after CVI 2017 run time update
Hello
I have a new PC with Windows 10 Professional 32bit ver 1706;
On this computer there were installed few LabWindows7 applications (only with run time).
Because I also have applications programed in newer versions of the LabWindows 2015, 2017, I decided to update run time engine on this PC.
After that, in every LabWindows application, there is missing "OK" button label in MessagePopup window (picture below).
Rest popup windows look fine.
MessagPopup returns no error;
First installation 2017 run time was correct, without any errors. After as I found the problem, run time was reinstalled and next completely removed.
I tried to find any registry entries connected with creating Dlg box in Windows but with no result; I tried to check if there are any problems with fonts.
I probably have to reinstall the system but before that I would like to ask if anyone had similar problem and like to share with the solution or have an idea what I can do anymore?
Thanks for any advice
(2,661 Views)
In my case a solution was to completely remove run time engine from system by uninstall and next by deleting all cvirt*.dll files from ~\Windows\System32\ folder. After that I install run time again and all labels look fine.
(2,616 Views)
