LabWindows/CVI
Mixed checkbox
Is there a possibility to create a mixed checkbox like in labview (https://www.ni.com/docs/en-US/bundle/labview/page/configuring-a-mixed-checkbox.html)
(2,793 Views)
If the mixed checkbox is the three-state unit with checked, unchecked and partially checked states like this one:
then I suppose you could fake it with a picture ring and a bit of coding: the click must switch checked / unchecked states, while the partial check is given programmatically when some other condition is met (in the above case only some of the child elements are checked).
(2,755 Views)
